WTD: set of 13" wheels ideally with yoko a539 tyres
mark chandler - 20/6/13 at 07:37 PM
Hello chaps
I am watching some on eBay, would rather buy on here.
Looking to do autosolo's in the little car so after a set of 13" wheels that will go over sierra rear callipers, ideally fitted with 185/60/13 yoko a539 tyres.
They must be road legal.
Minilights just fit, the minator copies are even better, WHY
Cheers Mark
welderman - 20/6/13 at 09:12 PM
Try tommyP in for sale section
hobbsy - 20/6/13 at 10:02 PM
I've got some what I think are genuine Minilites with Avon CR500's in 175/55 13 if those are any good to you?
mark chandler - 20/6/13 at 10:15 PM
Unfortunately cr500's are in MSA list B so not allowed, along with my yoko 048's
Sorry Joe, tommyP returns nothing useful for me, have you a link?
[Edited on 20/6/13 by mark chandler]
welderman - 20/6/13 at 10:20 PM
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=182504
mark chandler - 20/6/13 at 10:24 PM
Still MSA 1b tyres, and a bit pricey for my tastes, tatty and cheap is more for me
Should have been a bit clearer in my first ask.
dhutch - 21/6/13 at 07:02 AM
Unfortunately (for you) mine are not for sale, however I thought I would post simply because I have a set of the A539's in the 185/60R13 size on my car, predominately for the same reason as you, in that I use it for Autosolos and online research suggests the 539 was one of the better list 1A tyres.
I found I could buy a new set for £55 a corner from a local backstreet tyre place, fractionally cheap than online and inclusive of fitting and balancing, with the ford rims the're on costing £45 for the set from ebay.
I then saw an advert on here about a day later for a nearly new set of the same tyre, on rims, for 200quid odd, but thats life isnt it!
Daniel
mark chandler - 21/6/13 at 09:46 AM
Hello Daniel
I can only fit rims that will fit on my uprights and over sierra brakes, 6" then, I have a set of slicks I could pull off some rims although would rather have another set.
Thanks for the heads up on 539's my search continues
Cheers Mark
[Edited on 21/6/13 by mark chandler]
Rob F - 22/6/13 at 11:48 AM
Hi, if any use- I've got a set of 4 a539 185/60/13 tyres that you can have for £20
All have minimum 4mm tread. These were my wet set for racing, which means they have mostly sat in the garage for years.
The only downside is that they are pretty old, 3 have 2003 manufacturing date, and one is 2002.
Rob
