My lad has just bought a Fiat Seicento for a charity run he is doing later this year, however, he has got a puncture. The locking wheel nut adapter is so worn that it just jumps of the wheel bolt. He has tried hammering an old socket on to it and trying to start it with a chisel to no avail. What next, my "easy out" tools are not up to the job. Maybe I can keep drilling the bolt, increasing the drill each time until the head comes off. Any ideas please?. The problem is that as usual the bolts are recessed into the alloy wheel.
Different techniques work on differen designs. Could you put a picture up?
Most common is an old socket. It has to be a 12point and not a 6sided one. It also has to be only just too small to go over and needs a BIG hammer. If
that doesn't work there are removal tools that are basically a female easyout. On some lock bolts neither of these methods will work though...
After that it gets brutal or technical.
I doubt drilling and using a normal (male) easyout will work due to the torque required to undo a wheel bolt and you'd be there all week trying
to drill the head off.
[Edited on 10/3/14 by adithorp]
i had this problem on a saab,after many months with a pretty good tool kit,i gave up and cut the alloy wheel to bits with an angle grinder
Spent yesterday pondering this myself after I went to undo the wheel bolts on my 205...then realised I couldn't find the locking wheel nut tool
Mine are the type with 3 small holes in the face. The outer of the bolt head is simply a sleeve that rotates freely, which prevents the old socket +
hammer approach.
I'm contemplating trying to weld an M12 nut on the end and use that to loosen it, but it's a bit deep in the wheel.
Originally posted by nick205
Spent yesterday pondering this myself after I went to undo the wheel bolts on my 205...then realised I couldn't find the locking wheel nut tool![]()
Mine are the type with 3 small holes in the face. The outer of the bolt head is simply a sleeve that rotates freely, which prevents the old socket + hammer approach.
One of the bad ones. Drill down between the centre and ring (carefull not to break drill) then split the ring with a chissle (neede to be thin). The ring should then come off and remove bolt with either socket driven on or removal tool.
Watch this little video, skip to 1m 20sec for the action
http://www.dynomec.co.uk/video.html
I went to this guys office a few years ago and he removed mine for beer tokens in less than 5 minutes with no damage.
He also sells the kit but it may trigger a DIY removal method if you watch the video
Had a similar problem on a Volvo S60. Took it to the local welders and they welded a nut on and were able then to remove locking bolt. Hope that
helps.
Regards,
Arnie.
