Alternator for Ford crossflow
jonbeedle - 1/7/16 at 02:47 PM
Hi. Does anyone have an alternator for a 1977 Ford Crossflow 1300/1600?
britishtrident - 1/7/16 at 03:03 PM
If you are stuck I have one but the postage would be more than the value of the item.
Easier to repair your old one
It is just an ordinary Lucas ACR 17 very easy and cheap as chips to overhaul or you could fit a Lucaus A127 as used on the Escort 3 and some Sierrs and Metro.
jonbeedle - 1/7/16 at 03:10 PM
Thanks for the info. Not sure how to repair it but I'm sure I can find out.
britishtrident - 1/7/16 at 04:15 PM
Unless the diode pack is blown or slip rings are worn through new brushes and/or a new regulator pack will fix it no soldering involved. With alternator off the car just take the back cover off and
http://www.howacarworks.com/electrical-systems/renewing-alternator-brushes
rusty nuts - 1/7/16 at 07:37 PM
Hi Jon , haven't seen you for a while, hope all is well? Any decent motor factors should be able to help with the alternator , not particularly expensive
jonbeedle - 3/7/16 at 10:02 AM
Hi Rusty
Hope you are well. Yes it's been a few years. Maybe we can get together once I'm back on the road
rusty nuts - 3/7/16 at 12:59 PM
Look forward to seeing you.
