I have a 30 year old camper with a bit of a roof leak around a roof light. I removed the light mechanism, cleaned it up and resealed it with a good
quality exterior sealant. I still have a small leak in strong rain. Can anyone recommend a plastic type spray or brush on paint? I don't really
want to spend £60 on some two pack mix if possible.
Many tanks Jon
I used bitumen tape on my leaking sunroof. Not a drip in 2 years or so.
You don't specify exactly what you're trying to seal, but something like a windscreen stop leak type sealant might work, there's one called seek & seal, which is a thin liquid goes into the same route rain would take (hopefully!) & seals the leak from inside
Russ mentions windscreen sealant. By the sound of it a very runny one that runs in and finds the leak/gap.
After replacing an old fashioned (not bonded) windscreen some years ago. I got it "popped" in OK, but it kept letting rain in. I used a tube
of black goo-ey windscreen sealant. Working slowly around the rubber seal, outside between seal and car body and inside betwee seal and winscreen. It
takes 48hrs to go off, but worked a treat and stopped the water getting in.
The other trick if you strip and reassemble it is to have all parts as clean as you can possibly get them (and renew any rubber seals if you can).
Good luck!
You want some of this stuff:
https://www.ebay.co.uk/itm/126024991251?_skw=creeping+crack+seal&epid=2306096349&itmmeta=01JGXWNJ6SJBQZ68P11SSNQ2SQ&hash=item1d57acc213:g:
USsAAOSwEmNk6xWi&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKmDN0Md2LboX0aMDGFFkLR%2Fmt%2BPfRUjLv1JM7qMXtSWdLXjYNmuqv8pFY2mgYURqz8ofFm%2BTEY9VfSZ
2awX%2F97lSTmiQWlxyBJQTB0d4uKM4SxJTTZhhploaifz30q2%2FFO%2B9n017PkOVx7g9mNIncQ8uSHvKK1JEYR3cFDDcc0sEV5gSoPo1zVDz0unq%2BSPw5OwmHiyBgMEZSxh%2BF03ov3%2BLQ
qLDk9JqYt5uyZwkn39LuXY9y0siFSlzfQu74c8uLOrImDQ1fdE1o%2FLcGKiY%2FMsvrKStskGicPS97TK3uGU2g%3D%3D%7Ctkp%3ABFBMwKPWvIdl
I used it on a carvan roof that had a similar leak and it worked well! Heard of plenty of campervan folks using it too which good results.
Used CT1 on mine - no leaks after 12 months. very flexible and loads of colour choices.
