can you test an engine without a pump?
hellbent345 - 9/2/11 at 03:24 PM
Hi chaps
Im just wondering if you can test an engine without the fuel injection pump? I dont know if i want to go injection and throttle bodies, or bike carbs yet, but my car has its original injection system still on (but i forgot to take out the fuel pump! ) I would like to see if i can get it running with the original system first before buying a new fuel pump as if i can't run it, ive got to make the decision between bike carbs or throttle bodies. I guess if i do have to have the fuel pump, my decision has been made for me - ill have to do throttle bodies! If that is the case, can anyone recommend a good cheap high pressure pump and a good cheap low pressure one
Thanks Alan
phoenix70 - 9/2/11 at 03:36 PM
doubtful, you need the fuel pump to make the pressure at the injectors
owelly - 9/2/11 at 03:36 PM
It is possible to get an injection engine to run with a LP pump but it won't run correctly. Try getting hold of a HP pump out of an early injection VW. I got the pump out of a Golf GTi and the pump is mounted in a little plastic swirl tank complete with vapour trap, return and filter canister mounted on the side. Once you've finished with the VW set up, sell it to me for thruppence 'cos I need a spare!
ETA a piccy of the one I used. The dust came as an extra.
[Edited on 9/2/11 by owelly]
hellbent345 - 9/2/11 at 03:37 PM
damn i thought as much
anyone got any suggestions for fuel pumps on the cheap? ill prob end up doing a swirl pot setup
edit: thanks for the vw info, posted while i was writing this
Thanks, Alan
[Edited on 9/2/11 by hellbent345]
owelly - 9/2/11 at 03:48 PM
Like this, but get a cheaper one! Mine was a tenner from the local 'proper' scrappy.
Volkswagen Golf MK2 Fuel Pump GTi Pre 88 on eBay (end time 28-Feb-11 13:27:37 GMT)
Or this is a bit cheaper.
Golf Mk2 Gti Fuel Pump on eBay (end time 12-Feb-11 12:31:52 GMT)
hellbent345 - 9/2/11 at 03:53 PM
ive had a look on ebay and there aren't any that look like they are worth spending the money asked! However, i did a quick search for in tank fuel pumps to see what rubbish was floating around and got a few 99p starters - can anyone see any problems if i just get one of these and use it to test the efi i already have? (by inserting the pump in a bowl of fuel or something similar!) particularly with running the pump if its got a special connector (can i just wack a positive and negative either side of the pump? heres what ive seen so far
VAUXHALL ASTRA FUEL PUMP IN TANK 1.8 SPORT 2002PLATE on eBay (end time 10-Feb-11 19:26:32 GMT)
and
Range Rover Classic V8 Petrol EFI In Tank Fuel Pump on eBay (end time 17-Feb-11 16:38:43 GMT)
zetec - 9/2/11 at 04:39 PM
I've been to a scrappy where one bloke sat on the roof of the Mondeo I was looking at with a plastic container filled with petrol and a length of tube, he started to syphon the petrol down the tube and let it flow into the throttle body while his mate cranked it over! Worked a treat! But I suspect you are looking for something a little less basic.
I fitted a s/h Vx GTE fuel pump (external), cost £10 and still going strong 10K miles later, comes with nice easy push fit connectors.
matt_gsxr - 9/2/11 at 09:34 PM
you could fill a small tank, run a hose and use gravity.
The problem is that to get 3atm with petrol you'd need the tank about 40metres high.
The fuel hose would cost more than a pump...
Matt
Angel Acevedo - 13/2/11 at 02:40 PM
You could use an air pressurized injector cleaner pump.
You unplug the Pump Relay to do so.
HTH.
AA
