Self Cancelling Indicators
benners05 - 19/7/15 at 12:00 PM
Hi
Does anyone know where I can get the cancelling bit that fits between the steering wheel and the indicator stalk for a sierra steering column?
I'm got a rally designs steering wheel on.
Its about the FINAL thing to sort out before the IVA!!
Ben
loggyboy - 19/7/15 at 12:11 PM
Self canceling isnt required for IVA BTW.
Irony - 19/7/15 at 12:13 PM
Phew, I haven't got them!
[Edited on 19/7/15 by Irony]
benners05 - 19/7/15 at 12:19 PM
problem solved!!
Thanks!
40inches - 19/7/15 at 01:28 PM
Mine went through IVA without, but I sorted it after IVA because I kept forgetting to cancel the indicators.
scudderfish - 19/7/15 at 01:30 PM
If anyone does have the bits for a Ford column I'd be interested. I can't hear the relay and bright sunlight washes out the lights on the dash.
adithorp - 19/7/15 at 04:02 PM
Self cancelling isnt required for IVA but the spaced bit is required on Sierra columns to pre-load/centralise the top column bearing, along with the spring spacer piece. Without it you'll have play in the column.
Irony - 19/7/15 at 07:55 PM
I have fitted a buzzer and it is very annoying!
Xtreme Kermit - 19/7/15 at 09:25 PM
+1
Tried it once, didn't like it. Too annoying so I ripped it back out...
40inches - 19/7/15 at 09:29 PM
+1
+2
Had a buzzer, couldn't hear it with a lid on lol.
BenB - 19/7/15 at 09:41 PM
I just cut the end of a rivet and welded it to the steering column and filed it to the same shape as the fgord bit. Works great.
