Wiring a power socket
cerbera - 8/3/14 at 11:54 AM
Going to install a power socket but am falling over at the first hurdle.
As there are no instructions with the item I'm not 100% sure which is the positive and negative terminals on the socket.
Anyone help?
David Jenkins - 8/3/14 at 11:58 AM
I'd guess that A will be the +12v connection - but one way to find out is to use a multimeter to find out which terminal goes to the centre pin of the socket (or use a bulb and battery).
stevem427 - 8/3/14 at 11:59 AM
A looks very like the + to me. Steve.
Slimy38 - 8/3/14 at 12:07 PM
B is connected to the outer, so that is negative.
[Edited on 8/3/14 by Slimy38]
Proby - 8/3/14 at 12:47 PM
B is negative, (A) centre is positive, without a doubt.
scudderfish - 8/3/14 at 12:48 PM
These things try to make the earth connection before the +ve so that you don't randomly earth through something else as you push the item into the socket. That would make A +ve and B -ve
cerbera - 8/3/14 at 01:20 PM
Cheers guys, that's what I thought but it doesn't hurt to get a second opinion before I break something.
