Hi everyone,
I have been working away at a reverse trike project for around 3 years on and off now.
I never thought of doing a build diary or anything but I have been taking pictures as I’ve gone along.
I will leave a link to my Flickr below so you can see my progress and I’ll add some pictures below too.
It started as a chassis I got from eBay for £50. I was going to make a 4 wheeler but I saw some other reverse trikes on YouTube etc and thought they
looked fun. It is also easier to build as the whole rear end is done. Engine, gearbox, suspension etc.
I have modified the chassis as I’ve gone along. I’ve used locost bottom wishbones, Sierra uprights and mushroom tops, punto rack and column and fiat
500 headrest (because it’s round). Motorbike donor was a 2000 ZX9R.
I have been teaching myself sheet metal work, you’ll have to judge for yourself at the quality and styling but I welcome constructive criticism. It
was easier for me to work with metal for now than fibreglass. If I like what I create I can always take a mould.
I’ll put some pictures below. Please ask any questions and please visit the Flickr link for more.
Overall weight so far is 320kg (not much to add).
Flickr link: https://flic.kr/p/2kVGEWg
Dan
[Edited on 30/4/21 by dan8400]
Test to see if it works...
Trike[/
url] by [url=https://www.flickr.com/photos/152677313@N05/]daniel payne, on Flickr
Trike[/
Trike[/
Trike[/
Trike[/
Very neat, well done, nice project. If you like working in metal then why not. Probably stronger at the front end than fibreglass anyway and who cares if it is a little heavier.
Thanks myke.
I thought the same about the steel. I was concerned about how much weight I was adding. However, our forklift has a weigher device so I am able to
keep an eye on the weight anytime.
I am still learning with the sheet metal but I’m hoping to get this project done and on the road and under my belt so that the next one can be a
little better.
Dan
Looking great Dan - that's really coming together.
I'd love to know how these trikes handle on the road - I bet it's tail out action all the way!
Tony
Thanks Tony.
I’m curious to know too. It boils down to one video that really gave me the inspiration to start looking into reverse trikes and take the plunge, sell
my Tiger Supercat and fund this project. Funnily enough I spent most of the budget in the first two weeks otherwise the domestic government would have
spent it...
Link to Canadian trike
I ended up going a different direction with the body etc as I do not (yet) have the tools or experience to make a chassis like his. Neat thing
though
Dan
I have been making steady progress with the body on my Reverse Trike.
I am concentrating on tidying up all the panels and getting ready for filler, primer and paint. The grey primer is just cheap stuff blown over when I
finish for the night as I got fed up with constantly removing surface rust before I could do anything…
Dan
A few more…
Dan
[Edited on 18/9/21 by dan8400]
Wow - I really like that! Looking forward to seeing it on roads near me...
Thanks JC
Getting tools and materials together for filler and painting. So hopefully no too long now.
Where abouts are you in Lincolnshire? I’m in Midville between Boston and Spilsby.
Dan
Hi everyone
Well, its been a while. So I thought I'd post the most recent photos I have.
Progress has been almost non-existent this year so far. I am, however, at the stage now where I'm applying body filler. I have all of the paints
and consumables ready for giving it a blow-over.
One of the solutions that presented itself was the tail lights. I really struggled to decide how and where to fit them. They also needed to be legal.
In the end, a friend popped over one night to have a look and suggested burying them into the wing. Needs some fettling to be perfect but its a neat
solution.
The seat is a first attempt at upholstery for me, but I'm quite pleased with it. I formed the aluminium for the base, then riveted it to the side
panels. I then added some foam and stretched and glued the vinyl on. It may be good enough for now, even to get it tested and on the road before I
fiddle with it again.
The wiring is functional, just needs tidying in places. Brakes are in. I've driven it on an abandoned airfield and she goes well. If I can make a
half-decent job of the paint, I'll soon be ready to book an MSVA.
Any comments and constructive criticism welcome.
Untitle
d by daniel payne, on Flickr
Untitle
Untitle
Untitle
Untitle
Untitle
Untitle
Dan
Certainly looks very well made and I think you have nailed the styling. Good job
Thanks mrwhippy
That looks really well styled.
I'm not up with the MSVA regs. do you need to have a mount for the rear number plate as for IVA and is it ok to have the rear lights that far
forward.
I'm just asking as it would be awful to fail the test on small things like that. Great project all the same.
Thanks Keith.
Kind of you to say about the styling. I had a rough idea of what I wanted, but, basically did it on the fly. I did at least do both sides at the same
time to get some consistency. The side pods were bent/cut/welded out of 19mm tube to get a frame, then cladded in sheet steel. It was the easiest way
for me to do it. I may try fibreglass in the future.
The tail lights can be anywhere in the rear half of the vehicle. As long as you meet the minimum height and maximum width away from the outside edge.
Also, regs say it’s ok to have the red reflectors on the back of the front cycle wings, so that’s where they are. Some of the rules make sense, some
are odd…
There is a number plate bracket in between the wing stays. It is an aluminium motorcycle style bracket (cheap Chinese thing from eBay with included
light). Planning on fitting a square numberplate as it’ll fit the gap better.
Dan
