Hi all,
Just wondered if the collective could help me out here. I have a new Sony Bravia TV, it has 2 HDMI sockets (1 arc, 1 normal). I want to set it up so I
can run my Virgin media, Sony Soundbar and Blu-ray player.
The problem that I have is 2 hdmi sockets and I need 3 inputs. Is there a splitter or adaptor I can use to have 3 inputs that the tv will
recognise?
All this new smart tv stuff is a bit too tech for my simple brain and I'm struggling to get it set up and all working.
Any help appreciated.
TIA
Is the sound bar not connected by an optical cable on yours mine was? That means you would only need the 2 HDMI connectors for the virgin and blue ray
Depending on the abilities of your blu ray player or sound bar I would consider using them as the hub.
For example, run your virgin box and blu ray player into your soundbar and then run that into your tv. I found it hard to get arc running between my
lg tv and my pioneer soundbar. TBH I have been quite disappointed with the whole smart tv and equipment integration thing. I want one remote to
control all systems. Not one remote per device.
Know what you mean! Had my samsung smart and blue ray for 2 years now and still don't understand it. What you need is a teenager, they know everything techy with tele's, phones ect.
3 way HDMI switches are available quite cheaply (bewteen £5-£10) from Amazon or Ebay etc. which will automatically switch the active input to the
single output on the box which is then plugged into the TV.
You'd need to plug the Virgin box and Blu Ray player into the switch, and the soundbar directly into the spare socket on the TV as you
wouldn't want that to be switched.
Originally posted by MikeRJ
3 way HDMI switches are available quite cheaply (bewteen £5-£10) from Amazon or Ebay etc. which will automatically switch the active input to the single output on the box which is then plugged into the TV.
You'd need to plug the Virgin box and Blu Ray player into the switch, and the soundbar directly into the spare socket on the TV as you wouldn't want that to be switched.
Thanks guys, that helps!
Just on a side note, I purchased an LG first and although it was a great TV (ultra HD 4 k thing), LG arc does not work with many other systems. As my
soundbar is Sony, the LG tv would not work through it unless I used optical and then I had 4 separate remotes which was crazy. So I took the LG back
and changed it for a Sony.
If I have any other probs, Im sure you will hear.
Thanks again and hope you all have a merry Christmas
Why not just run everything into an TOSlink 3 way ...
Digital Audio Optical Fiber Cable Adapter TOSlink 3-Way Selector Splitter FJUK
or this..
3 Port HDMI Splitter Hub Box Auto Switcher 3 In 1 Out 3D 1080p HD 1.4 AdapterUK
[Edited on 21/12/16 by johnemms]
Sounds like a good excuse to go buy an expensive amp.
I run all mine through a Denon surround amp via hdmi and other digital inputs then one straight to tv. Much easier
Originally posted by nick205
At 42 I must sadly admit that technology has overtaken my ability (or desire). I recall having to program the video recorder for my parents, because they couldn't fathom it out.
What's a TV ?
Originally posted by 02GF74
We were so poor I had to watch the programs in black and white and summarise the program in a notebook cartoon strip style.
Originally posted by slingshot2000
What's a TV ?
A video recorder, thats luxury.
