I'm just about finished rebuilding a V8 Rover 3500 engine which had done about 100,000 miles .Before the rebuid the oil pressure was quite good
when warmed up (30-40psi) . Because i left the bottom end alone and only reground the valves cam etc i was wondering what engine oil i should use.
10W40 is reccomended in the manual but do you agree?
cheers
I would personally go with what is recommended mate.....
