Hi, I am looking at putting my Zetec into a caterham SV but it seems there are no standard exhausts for this setup.
Can anyone either tell me if the westfield Zetec exhaust fits in a caterham SV or anyone recommend a custom exhaust builder around
gloucestershire...or nearish?
Also does anyone know is crossflow engine mounts fit a zetec?
No idea about the exhausts, but I'm fairly sure the Zetec E we have is on different mounts to the Crossflow
We have a crossflow mounted with Westfield Zetec mounts, but to get the engine height right, we have had to raise them up 25mm by fitting spacers between the mounts and the chassis. Otherwise angles and mounting holes are the same.
Dave at Powerspeed Auto is very helpful and won't rip you off. He does a lot of exhausts for other kit companies.
Tel 01233 662225.
Have you tried a company called Raceline, they specialise in Caterham Zetec Transplants.
I am doing the same for my Caterham S3 and have ordered zetec engine mounts that allow the engine to sit at the same height as the previous crossflow.
They do a zetec exhaust system but am wondering whether it will fit a SV. It is probably worth giving them a ring.
www.raceline.co.uk
James
www.raceline.co.uk
James
Dave Tyler in Wootton Bassett did mine tel: 01793849430.
Does lots for the classic racing fraternity, only mild steel but has patterns for everything - bits of wire hung from his workshop ceiling.
He's very busy in the early part of the year so prob. worth contacting now.
Cheers, Pewe
Tube Engineers
Ardgraft Works
Newtoft Bus Pk
Newtoft
Market Rasen
Lincs
www.tubebending.co.uk
01673862286
Did a first class job for me at a very good price, built on the car so fits 100%. He was featured on one of the TV Kitcar build programmes and does
lots of work for vehicle manufactures.
Cuistom Chrome in Nuneaton, Wrwickshire will do it
Cheers guys, thanks for all the info.
I have previously contacted raceline as i have had bits from them before but they don't have any off the shelf parts for an SV.
Thanks for the mounts and exhaust info, time to start ringing around.
btb exhausts .
