and are they spaced the same as zzr1100 carbs?
really need urgent help on this one!
[Edited on 25/11/08 by blakep82]
Later ones do, earlier ones don't.. not sure of the model change.
I built my oinlet manifold using ZZr1100 (no TPS) carbs and later changed to ZX9R ones (with TPS) I presume your doing the same as me for megajolt?
The spacing is slightly different, the outside two on both sides are about 3mm further apart. As I used the original carb inlet rubbers I just slotted
the top holes slightly on the outside 2 and swung them out.
Using rubber hose you may get away without modding the inlet. But don't quote me!
If you look carefully you can see I've slotted the outside holes very slightly to move the rubbers out a bit
pretty much! i built my manifold for ZZR110 carbs, but now i'm coing up with problems putting in a TPS, and my carbs are pretty poor anyway.
could use a big refurb. considering getting something with TPS already in.
seen some on ebay, looked good, and pretty cheap. looked like TPS on the side. emailed the guy he said it doesn't have TPS on it! looked at his
feedback, and he sold another pair with the exact same description and photo.
but at least i know they did and they should fit, and actually, the spacing on the end two should work out a little better!
is £80 a decent price? (£70 +£10 post)
I think I have some ZX9R carbs in the garage. I'll have a look tomorrow evening for you
Image deleted by owner
Dave
cool! if you do dave, how much would you want for them?
I'm using ZX6R carbs - 37.5mm chokes, TPS and dead cheap. Should be able to get a set for £15 on ebay.
Stu
think i'm sorted now
£15?! blimey. ah well.
