Coming to work this morning and had a couple of notchy changes followed by the inability to get in or out of gear. I could get out of gear and
occasionally back in but very difficult to move the gear lever. When I stopped it was impossible to get back into gear, so I started in 2nd and drove
the remaining 21 miles to work in that gear. If you depress the clutch pedal fully, there is some horrible vibration. The car has done 170k, but the
clutch was changed when I had a gearbox problem at 128k(and the original was only half way through its specified wear limit). The garage has just
phoned to say it needs a new clutch, but I think its more likely to be a master/slave cylinder problem? What do you think?
When I dropped the car I gave it to one of the mechanics rather than 'the boss' who said ' Oh yeah, these civics are notorious for the
slave cylinder failing'
Fluid could have leaked away, could really be either slave or master.
The horrible vibration you speak of, would lead one to suspect the thrust bearing, guessing is a concentric job, the bearing face could have worn
away and the unit 'fallen' to peices....
I checked the fluid - all present and correct. I think you may be right about the thrust bearing. In the end I guess thats a new clutch then.
Didn't need stripped to spot what is wrong, pretty obvious the release bearing has broken up and damaged the fingers on pressure plate and the possibly the fork.
Do you sit in traffic with your foot on the clutch ? Thrust bearing can sieze and the fingers on the clutch diaphragm can break causing the symptoms you have. One of the biggest causes of clutch failure
I don't sit in traffic with the clutch in, its one of my pet hates!(My missus does but she almost never drives this car). That's why I was
reluctant to just believe his statement that it needed a new clutch. I think he's having a strop now as I can't get him to phone back and
say whats going on..... and I need the car at the weekend.
Thanks for all ideas
Regards
Hugh
Originally posted by hughpinder
I don't sit in traffic with the clutch in, its one of my pet hates!(My missus does but she almost never drives this car). That's why I was reluctant to just believe his statement that it needed a new clutch. I think he's having a strop now as I can't get him to phone back and say whats going on..... and I need the car at the weekend.
Regards
Hugh
Regards
Hugh
