Can anyone recommend a source for the above? Some car or other must have a pull-type slave as standard?
Rally Design sell the Wilwood one, but seems a bit pricey. Linky to Rally
Design
Can't say I can think of any production car that uses a pull type cylinder however ISTBC
Citroen Xantia 2.1 Turbo Diesel
The Mazda RX7 FD3 uses a pull clutch but with a convenional slave, just reversed so the clutch fork plls the pressure plate instead pushing it.
I dont suppose its much help though
Those Wilwood ones used to be cheaper before the $/£ rate went down the pan...
It's the only solution I know of bar fitting an internal concentric slave cylinder (and a Ford box conversion isn't cheap - about £120 from
Burton power)
