which diff oil & gearbox oil
dunk3 - 29/12/08 at 07:43 PM
Hi all I am ready to fill my standard sierra diff with oil, but not sure what grade to use. Plus what oil do i use in my type 9 gearbox. cheers..
tomgregory2000 - 29/12/08 at 08:30 PM
i used ATF in the gear box and special ford diff oil but i have a LSD and it was very expensive
A1 - 29/12/08 at 08:33 PM
im using some millers oil in the lsd diff, was about 15 quid for a litre. i bought it from fluke motorsport.
seems pretty good...not done much hard driving yet so not 100% sure.
minitici - 29/12/08 at 08:44 PM
If it is a Sierra rear LSD, it uses Hypoid SAE90EP oil.
It does not need special "LSD" oil as the lsd is a sealed viscous coupled unit.
IDONTBELEIVEIT - 29/12/08 at 08:55 PM
EP90
tendoshingan - 29/12/08 at 09:47 PM
I needed exactly the same,
from everything I found you need:
gearbox oil: standard oil grade 75W90
differential oil: EP90 GL5 spec
I think that's right
