Advice needed.....
People running bike carbs, what are you using for the joining rubbers? I've used Think Auto's fuel filler hose, but, the walls are too thick
and interfere with the throttle spindle fittings.
The airbox is mounted off the manifold so there is no weight for the connector rubbers to take, simulating the way carbs are mounted on the bike.
I've read varying accounts of using silicone, both perishing and lasting for years.
Thanks.
Pete.
I ended up buying the airbox from the bike breaker who sold me the carbs (£15 for the carbs, £5 for the airbox - plus postage). The airbox came with
the connecting bits.
Having the correct connectors does make a difference, as they have internal ridges that locate in matching grooves in the carbs (and I put some in my
manifold stubs too). This means that the clamps aren't so important for fastening - they keep a good air-tight seal, and stop the ridges popping
out of the grooves.
[Edited on 24/1/09 by David Jenkins]
R1 carb rubbers are about a fiver each from main dealers. They fit the carbs quite nicely.
I used the original carb inlet rubbers mounted on plates.
I have used these silicon rubber for 3years know but some people say its no good with petrol
carbs on manifold
Jacko
Silicon didnt work for me. Since changed to alfgomma hose but cant remember the exact spec. I got it from local engineering spares type shop. Wasnt expensive.
