Block age
vinnievector - 29/1/09 at 04:19 PM
Hi all SVA on the horizon now ,
Sva states i need a date for the eng iam using ,
Its a late eightes pinto i think ,so who do i write to if i give them the block num as it came from an unknown doner
address ext .
coozer - 29/1/09 at 04:23 PM
Ford technical centre are most obliging, send them the engine number and they return the letter next day.
Ford Technical Information Dept.
PO Box 300
Walsall
WS5 4QH
lotusmadandy - 29/1/09 at 04:27 PM
Just get hold of a burtons
catalogue.the data you need is all
there and recognised by examiners
as gospel.i have used mine three times
with no bother.
vinnievector - 29/1/09 at 04:29 PM
Thanks Guys ,
Hi lotus thanks for the advice hope to be on the road soon .
mcerd1 - 29/1/09 at 04:30 PM
the first 2 letters of the engine code will tell you - look in the burtons cataloge (they'll send you a copy for free)
its also on the website:
http://www.burtonpower.com/technical_1/ford_date_chart.aspx
(edit - too slow again)
[Edited on 29/1/09 by mcerd1]
Stuart_B - 29/1/09 at 04:39 PM
my examiner, said that burton power table is not proof, you need it to say your engine number and what age it is, not just 2 digts, what the eaminer said to me, if i were you i would write to ford, at least you know you are going to be ok.
stuart
dogwood - 29/1/09 at 06:43 PM
If you don't have the V5 then yes you will need a leter from Ford.
For reference:
The 2 letters on the block engine numbers, for Ford run:
A=1980 through to Y=2000
Excluding I,O,Q,and U.
The second letter denotes the month.
They don't run in sequence
HTH David
jacko - 29/1/09 at 08:24 PM
Did Ford,s make a pinto after 1995?
