After you guys told me to just block up the return fuel pipe on my 2.0 pinto that i am changing to 40s. What do i do with the vacuum pipe from the
distributor.
As there is no where for it to go on the manifold do i
A. block up the outlet on the dist end
b. leave it open ended
c, something else.
Do i have to do anything with the moving plate inside the dist, or is there a cheap dist i should be fitting instead, electronic already.
Cheers Richard.
When i fitted bike carbs to my pinto there was on place for the vacuum from the dizzy Bogg Brothers recomended i got a new dizzy from H&H
ignition solutions
tel 01384 261500
this may help you
Jacko
ps others may know another way to do it
Option 1) Drill / tap a take-off
Option 2) Go megajolt
Option 3) Just blank it off and see how it runs
Option 4) Get a "performance" dizzy that doesn't need the take-off
Option 1) - not great as you will get a loud ticking noise from the dizzy as the pulses of vacuum hammer away at the Vac Adavnce stop inside the dizzy - and it messes up the timing
Options 2 & 4 both good
Option 3 might be ok but will be a compromise between ok at high revs but poor at low revs or the ther way around.
Mark
Mark
Agreed - my preference of the order in which I would rate them would be
2 - 4 - 3 -1
If you do go for 1, then drill/tap a small take-off for all 4 inlets, join them together and put a little chamber in there to damp the pulses.
Hi
As mookaloid says above. 4 is the reliable easiest way foward. And H&H do some fabulous dizzy's for us to use in the locost racers with a
good advance curve in them they get my recommendation too.
Cheers Matt
