Does anyone know where i can get a sump gasket set for a Jag engine?
I want to inspect my motor before i rebuild the chassis after painting but can only find a head gasket set.
ETA - 3.6 AJ6
[Edited on 18-2-09 by speedyxjs]
Could you not make you own from gasket paper? Always an option. Otherwise instant gasket (like hylomar blue) though some people don't like it incase it blocks passageways....
Making you own is easy for small area's not so good for something as bit as you have. Small Ball pein hammer and paper.
Silicon is no good as it reacts to oil and petrol, Halfords do a nice sump sealant for around £7 in a squirty tube, just run a small bead and you will
be fine.
Lots of dealers use this stuff now, that why you rarely see oil leaks these days.
Regards Mark
Try www.jagspares.co.uk
Cheers, Pewe
