Hi
Having finally got hold of a QH CCT133 clutch release bearing to mate my zetec to a type 9 I'm not not so sure it is what it says on the box.
Can anyone tell me if this is right as it's nothing like a longer version of the original release bearing and I can't see how it will attach
to the clutch release arm?
Many thanks!
ct133?
cct133?
[Edited on 16/3/09 by DavidW]
I dont think it is (but i could be wrong)
Doesn't look like mine. Ive got a photo somewhere - I'll try to find it...........
Chris
I am struggling to get the photo to upload but there is a photo in my archive of my CCT133. It is on the right and the std (CVH/type 9) version is on
the left. Hope this helps
Chris
Thanks Chris!
I definitely have the wrong part.
Bu**er, IVA here I come.
Join the club - there is no way I am going to get finished in time for SVA!!
Have you tried Wilkos for the clutch release bearing?
Chris
I picked this one up from Wilcos today after a 2 week wait...
Arrgghh!
A mate of mine got one from there a few weeks ago so Ill have to check with him to see if his was ok! They seem to be getting harder and harder to
come by.
Chris
I bought one of the shelf from a company called partco if it helps.
Pic
I've managed to buy 2 on ebay before now, both Powertrain (not QH) - will dig the number out later.
B.R.T Bearings in doncaster do them, part number BRT 220. Telephone number is 01302 730688. I had trouble finding one aswell but after a post on here dunk3 came through for me with a suplier.Think it cost me about £23 ish.
Mate would you believe they sold me one the same as that first definatley wrong. The one on Norwich road?
Kick up a fuss they should get it next day. If they say theyl get you one from there felixstow shop tell them to do one.
The replacement Wilcos got in was just the same...
Time to try BRT.
Powertrain part number is PTCB523 is that helps - listed as Capri 1600 OHC and Cortina - also some Sierra 1300's
Have you got one sorted yet?
I now have one on the way from BRT - A bit steep at £24.80 plus £7 p&p but if it works I'll live with it.
I now have the BRT 220 bearing and whilst closer than the first attempt is not quite the same dims as the drawing above. The 35mm dimension is more
like 27mm with the 18mm being the same. The overall height if 38mm.
ETA: All sorted - The BRT direct equivalent for the QH part CCT133 is a BRT388 available for £23 plus P&P next day delivery from the BRT head
office - 01945 464097 - http://www.brt-bearings.com
