does anybody know how much oil goes in a 2ltr pinto with rs alloy sump?
Would think it will be about the same as with the normal sump on. Isnt the alloy sump shaped to keep the same volume of oil?
If not i doubt it will be much less than with the OEM sump
which is?
Take a look on ChrisG's website..he has the full service data for the 2litre pinto on there. The direct link is;
http://www.gibbs111.fsnet.co.uk/pinto.htm
Hope you dont mind Chris
thanks
No problem mate, that's what its there for!
ISTR that the RS sump is the same capacity.
Chris
