Has anyone used one of these adapters with a ford speedo sensor to run an electronic speedo? (as shown on page 84 of the 2009 burton catalogue)
Any problems with it? Anything good/bad to report?
James
i bought on, haven't fitted it yet, so i don't know. but i'd be interested to know what others say.
also if anyone knows where i can get the other end of the plug for it...
I use one and it works well with my smiths telemetrics speedo, make sure you have enough clearance between your tunnel and the socket though, i dont
have a burton catalog to hand, but i think i got mine form there so am assuming its the same one. Its about 2" long and 1.5" wide so if
your tunnel is tight it may be a pita to get it in.
For me it was worth every penny as my magnets/pickup were giving me no end of problems.
Cheers for the feedback. I've just been and measured up and the width looks like it's going to be tight, plus I've added a bracket just
in that area to support the brake line! Doh.
Think I'll get it then re-work the tunnel. Like the idea better than trying to get the radius on a cable or paying for a 90 degree converter.
Originally posted by irvined
I use one and it works well with my smiths telemetrics speedo, make sure you have enough clearance between your tunnel and the socket though, i dont have a burton catalog to hand, but i think i got mine form there so am assuming its the same one. Its about 2" long and 1.5" wide so if your tunnel is tight it may be a pita to get it in.
I made a sender!
(yeah, I know, smug bu**er)
Here 'tis, without its lid...
speedo sender
This fits instead of the speedo cable on the type 9 box.
The material cost was almost zero (just the cost of a hall sensor & magnet) but if I'd added up all the hours it took to design and make, I
could have bought a new gearbox & commercial sender!
[Edited on 17/3/09 by David Jenkins]
Who does the 90 degree converters, just need the information for a just in case as I have not around to fitting the speedo yet?
Adrian
Adrian
got mine right hee, its 2 and a half inches long. plenty of room in my tunnel thankfully
mine is in the post, hope to get it tomorrw
Thanks for the link. £95 OMG. Time to get the lathe and milling machine working going and some bevel gears.
Adrian
Ordered, should have by the end of the week and see what the clearance is like!
Yeah, the 90 degree converters dont seem like great value!
Anyone got one of these, or some photos?
cheers.
