After removing the 1300 engine, I saw lots of needle rollers inside the end of the crank
that I believe belong to the spigot bearing.
There is no mention of replacing this in the Haynes, so is this part available and how does one go about fitting it?
Hopefully it is all dandy in the new engine but would be useful to know.
Ford sell 'em
They arent expensive, you need to remove whats left of the old one though.
I've removed them in the past using 1 a slide hammer,2 a rawl bolt with mole grips and hammer, 3 a close fitting drift after filling the center with grease and 4 a dremel type tool. If you get stuck Burtons sell the bearing
Mine pulled out witha pair of needle nose pliers. got the new one of ebay for £1.50 and pressed it in really easy
aren't the tapped into a blind hole? in whcih case how do youo get one out? smack with chisel to split the race?
