Heat isolation
scudderfish - 20/3/09 at 08:16 PM
I have my ignition amplifier bolted to a large piece of aluminium to act as a heat sink for it. Unfortunately, the only convenient place to mount it is bolting it to the cylinder head, which I think is going to shunt heat into the amp rather than away from it.
Are there any sort of washers I could use to reduce the heat transfer from the head to the sink?
BenB - 20/3/09 at 11:06 PM
Ceramic washers?
Hope you've got some air flow over that amplifer if you're doing that! The ambient temperature around the h/sink is going to be huge!!
Personally I'd find a different place to bolt the amplifer. Other than bolting it directly onto the exhaust header you really couldn't find a worse place!!!
