tuning megajolt on a pda
Danozeman - 24/4/09 at 07:06 AM
I have seen you can run the megajolt tuning thing on a pda rather than a pc. What do i need to connect it up?
GregSL75 - 24/4/09 at 07:20 AM
For megasquirt you need an old Palm PDA, I ot a Palm 3C (Palm IIIC) on ebay for £10.
Also need a null-modem and the free software, there's about 3 different ones, if you do a google search for Palm and Megasquirt you'll get them up.
Works quite well, I use it as a digital dash, gives you a readout of any parameter the MS knows, revs, spark angle, temperature, throttle position, map sensor etc. etc. Plus the IIIC is colour..
MikeRJ - 24/4/09 at 08:44 AM
Megasquirt software is not compatible with megajolt.
There was a Pocket PC application called "Pocket Spark", but the original host website has been down for a long time so there have been no updates and I don't know if it's compatible with the latest MJLJ firmware. If you want to give it a try you can get a copy from the Autosports forum.
Obviously you will need a Pocket PC that has a serial comms port, most modern ones are USB and not suitable.
[Edited on 24/4/09 by MikeRJ]
