big valves
jpindy3 - 3/5/09 at 06:31 PM
hi,i got a big valve head,i was thinking of using it on my turbo pinto,will the valves take the heat or do i need turbo ones,if there is such thing???
i think thay are good valves as its a vulcan head.
thanks
jamie
snapper - 4/5/09 at 06:44 AM
Normal valves are fine unless you go for really stupid boost pressure, by then you would have coated the pistons and exhuast tracts. Then you would consider sodium filled valves.
In reality your head should be fine.
jpindy3 - 4/5/09 at 07:20 AM
thanks for that,somone one another furom said that,result !
