hi all take a look at my pics,the ones that are labled p,
i think i cracked it,
i had to borrow some cash
jamie
also its not in any of these pics,what i have done is,block off the small outlet on the stat,that hose gose to the top of the tank,but thereis a therd
outlet on my rad a small one im useing this to go to the top of the header tank to let air out of the system,
as it is the highest point!
is this ok?or not?
[Edited on 14/5/09 by jpindy3]
Samco porn
Like it!!!
Could those photos be any bigger?
looks good mate.
looking good, did you get sorted with wheels?
mine are here if you need them.
cheers
andy
cheers
andy
Hi Mate the pipe work looks very nice
Can i ask about the way you have piped it up
have you tried it on the road yet ?
there is just two things that i am not sure about
on my car the pipe coming out the inlet manifold [ you have blocked ] goes to the top of the header tank and the bottom of the tank gose to the 5/8th
pipe on the water pump
doing it this way gets air out the head
having said that if your way works ignore me
Jacko
This is mine it's been like this for 5 years
Jacko
engine 2
on my car the pipe coming out the inlet manifold [ you have blocked ] goes to the top of the header tank and the bottom of the tank gose to the 5/8th pipe on the water pump
Jacko
I've done mine very similar to yours, jp; see my archive pics.
From the pump to rad lower (Polo), I used:
38-32 reducer hose,
32 Al joiner,
135 degree 32 mm elbow,
32-32-15 Tee, (15mm goes to header tank)
and a wiggly hose.
I still haven't resolved the fluctuating level with the system unpressurised - maybe it settles under pressure.
We'll see when my hands recover a bit more (after getting well soaked in ATF)
John.
