Are Weber DCNF carbs any good to me ?
I have a crossflow.
Obviously to make them fit I'll need a manifold.
Does such an item exist, if so one for twin carbs ? Where can I get one from ? Any sellers here ? Any trade places ?
'Scuse my ignorance.
There is a manifold listed here
http://www.piercemanifolds.com/mangoletsi.pdf
[Edited on 5/3/04 by wicket]
I had a car with these on once and they were ok, but suspect that you would have a problem with the fact that they would stick up out of the
bonnet.Maybe you could use a foam type air filter above the bonnet as per single downdraught carbs.
Paul.
I have a crossflow.
