I've asked for more pictures of this sump on ebay
clicky but wondering if
it's possible to tell if this is what I need for my 2 litre blacktop. Seller says it is, but you know what they are like
Mark
If it is for a Zetec it will fit, I'm using a modified silvertop sump on a blacktop.
If you want a windage tray in there, may not be neccesary looking at that sump you'll need one from a silvertop, also the double ended main cap
bolts, and 4 spacers machining up, like this:
Phase 2 windage and pickup on
Is that a shortened Sump or a Standard.
If it is standard Zetec then you will ground out all the time
Try and get a short sump
Blacktop sumps are dead easy to shorten if you can weld, or get someone to weld for you.
Stu
seller said it was 7 inches deep, to fit the 1.8 silvertop or 2.0 blacktop.
Is this shallow enough
Stu
