Is the 3S-GTE engine the same basic block as a 4a-ge? i.e. will the Raw bellhousing bolt up between it and a type 9?
Or are there any other Toyota gearboxes that bolt up to it?
Mike
I think the W55 gearbox has been successfully used to convert the 4AGE and the 3SGE to RWD. I'm not sure about the 3SGTE though, I imagine it would have the same bolt pattern as the 3SGE.
Mike
It is different from the 4age, but the same as the standard 3sge, can get custom bellhousing to a t50 gearbox, but more common is a w55, w57 or w58
gearboxes with the right bellhousing will bolt straight up. And will handle the power of a 3sgte (t50 won't last long with a turbo 2L)
check out the following to find out about which bellhousings work
http://forums.toyspeed.org.nz/viewtopic.php?t=73257&highlig
ht=rwd+bellhousing
Linky
tony
Should really have thought about searching first, but I'm sleep deprived this morning!
Mike
Hmm, I've got this lying in the garage... W58 I believe
Was attached to a 21R engine.
[Edited on 10/9/09 by coozer]
Originally posted by coozer
Hmm, I've got this lying in the garage... W58 I believe![]()
