i have just fitted my engine, and found that my engine is off level and maybe a bit low. what do you guy's think???
please see photos below...
and this one
and this
Looks a bit low to me,sump to ground clearance needs to be around 100mm
if ur worried, add about a inch to your engine mounts and leave te gearbox mounts alone, that will raise the front and level itout, and aso icrease ur ground clearance, mabye add a little extra to ur O/S mount to level it the otherway
Make the mounts longer or add a spacer to the chassis.
How far off the ground is the sump? Make sure the wheels are on it too (something I wouldn't do then I'd have the engine 3ft off the ground once the wheels are on!)
Quote:- How far off the ground is the sump? Make sure the wheels are on it too (something I wouldn't do then I'd have the engine 3ft off the
3Ft sound a bit high to me
Or am I missing something???
[Edited on 12/9/09 by avagolen]
