Ford Auto Bellhousing?
coozer - 22/9/09 at 12:06 PM
Anyone got a rwd autobox lying around? I would be interested to see if the bellhousing comes off, and if so, how deep it is compared to a manual bellhousing..
Anyone got one, or know where the knowledge can be found?
blakep82 - 22/9/09 at 12:09 PM
mm, who's that bloke on here with an auto box? MautoK i think? he should have your answers
morcus - 22/9/09 at 12:57 PM
As above, He used a seirra auto I think.
I wouldn't have thought you could use an Auto Bellhousing with a manual box.
MautoK - 22/9/09 at 01:05 PM
Hello!
Here's an A4LD and Type 9 side by side:
A4LD & T9 - 1
A4LD & T9 - 1
I'll have a closer look and maybe take a pic into the b/h later if I can find the camera...
John.
MautoK - 22/9/09 at 01:25 PM
Looking into the bell housing:
A4LD B-Hsg
A4LD B-Hsg
and there's a 3mm thick gasket thingy between the b/h and main case:
A4LD Gasket
A4LD Gasket
You'll want to know how deep the b/h is, won't you?
It's about 6 1/4" from the front face of b/h to the front of the gasket thingy. Type 9 cast iron b/h is about 7" total length.
Sounds to me like a possible way to a lightweight bellhousing for Type 9 with a bit of macining and a spacer?
HTH
John.
MautoK - 22/9/09 at 01:31 PM
Bear in mind that the starter motor lives on the other side on the auto - don't know if the auto starter is the same as manual or different.
A4LD & T9 - 2
A4LD & T9 - 2
John.
coozer - 22/9/09 at 04:36 PM
Thanks for that John.
I have a Toyota Supra box I want to use and the auto bellhousing looks better to modify.
The shorter length gives me room for an adapter plate
