would I get away with using 32mm hosing on a 30mm connection if I made sure it was properly secured
wrap the connector in some PTFE tape
and a good tight hose clamp
probably - try it and see
can you get 2 hose clips on it - might help close it up a bit better
As per CBS tip of the month.
Cut apiece of Bicycle innertube and stretch that over the smaller tube, more than on if needed then connect hose & tighten.
RD
Originally posted by franky
would I get away with using 32mm hosing on a 30mm connection if I made sure it was properly secured![]()
RD![]()
cheers all
I had to use a 2mm bigger hose on a smaller connector and just put 2 jubilee clips on.
No probs so far
