what size has the hole got to be for unleaded fuel? can't find it the manual
is it 13.5mm or something?
23.6mm or less. Not too much less though else you won't get a nozzle into it!
It's 23.6mm diameter for SVA.
Don't think it changed for IVA.
Mike
hmm, just searched the manual for "23.6" and it doesn't come up lol
cool thanks guys, so less than 23.6mm but whats the size of the filler nozzle? don't want it too small! going to get one cut from aluminium to be
welded into my tank
I dont think a restrictor is in IVA as the only petrol avail is unleaded. so no need to diferentiate
only unleaded was available for SVA too i think. well, unleaded and diesel.
i thought it was to stop diesel being put in as the diesel filler is bigger isn't it?
Made mine 23.0mm which is no problem at the petrol stations...
Pics here: Linky
Ed.
Pics here: Linky
Ed.
Restrictors only need fitting on post 95 engines. We manufactured one and fastened it into the neck with rivets. There was a lip inside the neck for
the restrictor to sit on. We then drilled above it in three locations and popped a few rivets to hold it in place.
Phil
my plan was to have a 2mm plate cut out and sort of tack it in at 3 or 4 places (fill the tank with water to expell any gas?) don't mind if it
falls out up the neck at some point
Ed's solution looks good too though, might go for that. sure someone on here can make something in some kind of plastic for me too
engine is a 1998. i didn't think that one through well when i bought it lol
[Edited on 24/11/09 by blakep82]
note sure which i like best
