Does anyone know what thread bolt I need to fit in the mount point cast in the bottom of a Type 9 G'Box? Seems a bit bigger and M10 and a bit
smaller than M12... (M11 maybe
) but I think it might be old money. I had to grind through the original one and it seems to have got lost
since...
Tom
sounds like they might be 7/16 unf, same as seatbelts
It M12 I think from memory. Deffo metric. Its probably full of crap!
As Northy said,
I too remember it being m12, it's not imperial.
Mark.
I've just measured mine, its M12x2mm offset, 39mm of thread from the upper face of the elongated hex section, 19mmAF.. This has a M10x1.75mm threaded section in the base, which is 24mm deep (I haven't a clue why it is there!)
The threaded section in the base is to allow a bar to be taken from the mount to support the sierra exhaust.
Now is it normal or left hand thread ? (cause mine won't shift from my box
They are both normal thread, the threads have probably eaten into the ally of the box, a little heat and a good welt with a ballpein should do it
Blimey lads that was quick going!
I'll go and give it another try tomorrow with an M12. Now I think about it It's been painted so the thread could be full of crap.
Thanks again
Tom
