Iīm now ready with my modified oilsump for Pinto. One thing is for sure, I will never be a pro-welder
First the oil pick-up pipe
Then my sump
Stealth!?!?
Well....itīs black and not a single right angle
Looks good.
Does it leak? I had great fun (not) making mine water tight.
Did you weld the oil pick up pipe? I silver solderd mine but made a bit of a hash of it, if I had welded it life would have been better.
[Edited on 14/4/04 by GuyA]
Well, I had to weld it a couple of times before it was leakproof (!?!)
I did weld the pipe to.
Jonte,
You could also do a canny line in shower heads...
Originally posted by Hellfire
Jonte,
ATB![]()
