Fuel return pipe
Findlay234 - 18/4/04 at 02:46 PM
Right as you may well know im using a 4age with efi and i now find that there is a fuel return to the tank. Does this mean that i need to have two pipes running through the trans tunnel? the regulator and fuel return start at the fuel rail on the engine. Do i need a fuel return??
theconrodkid - 18/4/04 at 03:03 PM
you will need the return,normall on the outlet from pressure reg
Findlay234 - 18/4/04 at 03:51 PM
B#gg#r need more fuel piping then......
britishtrident - 18/4/04 at 03:52 PM
The return can/should be a smaller diameter
DEAN C. - 18/4/04 at 08:29 PM
8MM feed pipe and 6mm return pipe are standard for the 4AGE
