Gasket paper, How thick ?
big_wasa - 31/1/10 at 04:41 PM
As title really any advice on how thick to go for ?
Its for a zetec inlet manifold. I was thinking of 1mm ?
Any one got an opinion or advice on going thicker or thiner ? pro's and con's
cheers
will121 - 31/1/10 at 05:09 PM
are you using the orignal inlet plate/manifold? if so should be fairly flat so would think 1mm gasket material with a smear of sealant be ok, if using a with a home made manifold might not be as true/flat so a softer/thicher material may be better, the standard gasket only has a 0.4mm gasket paper each side of a plastic heat insulation core with a addition of engrained sealing rings
UncleFista - 31/1/10 at 05:32 PM
I used this , cheap enough and a single A4 sheet of the cork-type-stuff can be cut in half and used to do the whole thing.
I used it over a year ago and it's still going great guns
[Edited on 31/1/10 by UncleFista]
big_wasa - 31/1/10 at 06:02 PM
steel plenum so may not be as flat as oe.
I will just by the 1mm me thinks and see how I get on. 1m square will last a life time.
owelly - 31/1/10 at 06:04 PM
Tell me what and how much you want and I'll pop some in the post for you. U2U me your address.
big_wasa - 31/1/10 at 07:21 PM
Thanks Owelly, ive now bought a life times supply
dhutch - 31/1/10 at 10:48 PM
Originally posted by will121... 1mm gasket material with a smear of sealant be ok....
Gasget AND sealent.... wash your mouth out. lol!
owelly - 2/2/10 at 10:19 PM
I have access to rolls of the stuff!!
