I have at least 3 ways of plumbing the raditor bleed to the header tank, as shown in following (wait until I have posted all 3 options!!)
option 1 - route pipe along radiator then over the spark plugs, trying to keep pipe away from the exhaust.
option 2 - take hose diagonally over te rocker cover - uses 1 less joiner plus and shortest hose
option 3 - takes hose over the carbs.
I kinda like 1 and 3 due to nice lines nad probably 3 since the hose will be supported by the carbs; I cannot forsee the hose being so close to the
carbs posing any problem.
So whadday reckon?
i have the same layout as n.1, not had any problems with heat from the exhasut.
I personally think 3 looks the more elegant solution.
No 1 would look better if you had a straight piece of ali tube where it goes across the exhaust.
[Edited on 13/4/10 by Confused but excited.]
i would probably just go number 2. as long as the middle of the pipe is not the highest bit
No 3 looks good
I think number 3 looks best.
ooooh, level peggings at the mo.
The joiners will be 10 mm aluminiium tube from B&Q - just need to figure out how to put flares on (thinking a couple wraps of aluminum MIG wire
then lumiwelded on).
The aluminium will pass the heat from the exhaust - it gets rather hot in that area to the water - not sure I like the sound of that.
No3 for me
number 3 looks to me like its just resting on the carb/filters and brake resevior, which i don't like tbh.
if you want to avoid the exhaust, what about, like option 1, but fixing it down the carb side of the rocker cover?
No 3
3
Another vote for #3.
Just as an aside. Every bit of water that flows through the breather tube will bypass the radiator matrix and not get cooled. This could amount to a
fair bit given the bore of the tube you are using.
Consider some form of flow restrictor in the breather tube, maybe?
I'm not 10% au fait with crossflows though, I may be over-reacting.
When the thermostat is closed, is there any flow at all through the system?
Geoff.
Just as an aside. Every bit of water that flows through the breather tube will bypass the radiator matrix and not get cooled. This could amount to a fair bit given the bore of the tube you are using.
may look like it but deffo not resting on the reservoir.
no matter how I plumb it, it will be resting on the engine so there will be some movement or a long unsupported run - not sure if that is pissible unless I use an aluminiuim tube.
What about moving the header tank to the front like Caterham do?
A pair of Oyster pliers from B@Q.
Check this thread
[Edited on 13-4-10 by 40inches]
I'm going to stick my neck out and go with no. 2, but with a slight mod.
Run the hose down the intake side of the rocker cover (not over the top) and fabricate some ally brackets and rubber lined P clips to support the pipe
of the rocker cover or inlet fixings.
Keeps the hose away from the carbs and exhaust and if done carefully could look like an OEM type installation
