firstly sorry for the big picture.
in a nut shell given the correct position of the starter motor will this work. the toothed gear is machined acuretly to be a tight fit and central on
the propshaft. when the item is finished the wheel will be shrouded in 3mm steel for protection. and balanced properly. my main concern is will this
cause vibration when running
[Edited on 12/5/10 by 24vseven]
My eyes, my monitors!
Don't like that at all.
Yes, it may be encased in 3mm steel, but if it does go wrong.
It's putting loads of potential stresses onto a bit of the driveshaft which really doesn't need to have such issues putting on it.
The only suitable place for a gear like that is at the end of a shaft.
problem is room at the back is very tight
/ Agreed !
If that goes walkabouts at any kind of speed , it would probably kill you
Edit - too slow , I was agreeing with Zillspeed
[Edited on 12/5/10 by clairetoo]
Do you have a centre bearing on your prop with a rubber bush? If so gears meshing and turning may flex the rubber bush letting the prop move, and the gears push away from each other. My electric reverse has the sprocket bolted between the prop and diff flanges. Since the diff is solid mounted the gears will always mesh properly
fair point never thought of that
Can you find a starter that rotates the other way and then have the gear cloder
to the end ?
to the end ?
sorry but thats just wrong
like driving around with a horizontal mill in the car LOL
I would certainly be rethinking that
I have only built them on trikes, but 2 successful electric reverse systems so far
1st was very simple, pivoting electric motor with rubber wheel that acted on a portion of the shaft right by the diff
the second was far better, again an electric motor, from a wheelchair or some sort of electric vehicle
toothed belt and pulley to give the desired gear reduction, but the pulley on the propshaft ran on a large 1 way bearing. even had a speed control on
that version
the common theme being little or no rotating parts during forward motion of the vehicle, and always right up against a supported section of the
propshaft to prevent undue sideloading and stress etc
Nooo, dont do that
Generally in engineering - if something looks wrong it usually is. And that defo doesnt look right.
I dont know how most do the reverse stuff, but its probably worth talking to mk about how they do it?
If you're dead set on that move the gear as close to the UJ as possible, preferably with the starter motor facing the other way (so need to
change direction of rotation).
I'd advise you to find another way if at all possible.
the further a mass is way from centre of rotation, the greater the vibration if it is out of balancve.
it would not surprise me if the prop would wobble in the middle - the furthest away from both fixed ends and then placing a weighted wheel like that,
not good, as they say.
lol yea i took the if it looks wrong it usally is attitude hence the need for a second opinion so its back to the drawing board we go
it would not surprise me if the prop would wobble in the middle - the furthest away from both fixed ends and then placing a weighted wheel like that, not good, as they say.
how would the starter stay in mesh arrangement with the prop??? the prop will move up and down..
