Anybody know where this hose goes? I have removed the A/C pump power steering. I wondered if it was something to do with that
No picture, if you get a pic working, i'll try and have a look this evening before it gets dark
Sorry didn't manage to do it this evening before it got dark. Maybe you can send me a U2U and i'll try and remember to check tomorrow.
Regards
Ed
It's the pipe that connects the charcoal fuel cannister via the purge solenoid valve. Any fuel that evaporates when the vehicle is parked gets
stored in this cannister and is dumped into the inlet manifold at oppurtune moments by the ECU.
I chopped it off of my engine and bunged up the hole with TigerSeal. Works fine.
The other one is for the brake servo - also chopped and bunged. The only one I've got left is the one connected to the fuel pressure
regulator.
Ed.
[Edited on 9/6/10 by Madinventions]
Vacuum pipes
Ed.
