RV8 Fuel Pump and line options
Irony - 22/6/10 at 10:28 PM
I am starting to think about the fueling system in my RV8 Viento/Webber 500 build. I have a few questions:
1. What's the minimum thickness fuel hose i should use?
2. What fuel pumps have you more experienced V8 builders used and what are your thoughts?
3. What fuel pressure suits the webber?
Thanks in advance
Simon - 22/6/10 at 11:24 PM
Following from when I had SU's
I'd suggest a minimum 8mm id for the fuel line (though I'm sure I've heard of 10mm).
Pressure with a carb I doubt would need to be more than 4 - 5 psi and as for fuel pump, I used a facet solid state thingy.
Simon
craig1410 - 22/6/10 at 11:58 PM
I've got a Carter pump with 10mm pipe on mine and it seems to work well with twin SU carbs. No return pipes as the pump is self regulating.
Hth,
Craig.
scudderfish - 23/6/10 at 06:14 AM
I use 8mm hose, and I've still got my LP rattling away feeding my surge tank for the EFI bits. On it's own it fed my carbs fine. I believe it is a Facet pump.
wilkingj - 23/6/10 at 06:37 AM
As Flak Monkey Says... 8mm Pipe will deliver enough fuel for well over 300bhp.
I have 8mm pipe and 200bhp and a Webber 500 on my V8 and it works fine for me.
