How much
adz h - 29/5/04 at 07:18 PM
I've been quoted £1,233 for webber alpha kit for a zetec engine. Is that right?!
zetec - 29/5/04 at 07:51 PM
Probably. Best check out other options before handing over hard earned. Weber set up can only be changed by a Weber dealer. Other ECUs can be set up with a PC or laptop with simple software. I used Emerald which was supplied with a zetec map which was fine tuned on a rolling road, and I am able to alter anything I like with ease...idle speed, fueling, coolant fan on/off, ignition etc etc.
As I say there are lots of options. Checkout Jenvey web site, they give loads of info on injection and ECUs and links to some of the better known companies.
adz h - 29/5/04 at 08:02 PM
I haven't got any of the injection system for the engine is there any other option, other than webber carbs?
macspeedy - 29/5/04 at 08:03 PM
yep there are lots of manufacturers of throttle bodies try google
adz h - 29/5/04 at 08:05 PM
Thanks people
cosworth - 29/5/04 at 08:26 PM
Try ShawSpeed they do lots of engine kits
email info@shawspeed.com
mangogrooveworkshop - 29/5/04 at 08:33 PM
STUPID QUESTION Has anyone got through SVA with a late model zetec on carbs no cat?
zetec - 29/5/04 at 09:56 PM
I suspect very unlikely. I have heard people passing later test with carbs and a special cat (which fell off on the way home).
phelpsa - 30/5/04 at 06:58 AM
£1233 sounds quite good from what I have read in 'Performance ford' magazine. The going rate at the moment seems to be nearer £1400.
Adam
britishtrident - 30/5/04 at 08:07 AM
Emerald is a better bet see info on Dave Andrews excellent site -- Dave Walker is one of "us" --- good guy
NS Dev - 31/5/04 at 08:25 AM
Adam
I completely agree! That sounds a good price!! (though obviously not "locost"!!)
The ecu alone (£500ish) may be much cheaper but you are not going to get the throttle bodies cheap, direct from Jenvey the cheapest ones are around £385 +vat for the ones that fit onto a weber inlet manifold (which itself is another £70 +vat if bought new) the throttle pot is at least £20 etc etc etc
