Fireblade Oil Filter
IainL - 1/8/10 at 07:02 PM
I'll be trying to start my engine for the first time since buying it, but firstly I need to change the oil filter, oil & plugs.
I'm having trouble identifying what filter I need, therefore could any provide me with a part number for an oil filter fitted to a 919 carb'ed Fireblade.
Iain
ReMan - 1/8/10 at 07:51 PM
Champion F306 (halfords)
I would leave buying new plugs until you've finished fannying around
They are not cheap and if you are not careful you will be changing them again soon. Do a search.
Change them when youve got it all sorted and running
MK9R - 2/8/10 at 06:45 AM
once you have changed filter, remove plugs and turn engine over and check you have oil pressure, it quiet common to get an air lock. If there is no pressure, just loosen off the filter so it leaks slightly and turn over again. screw back up tight and then it should be fine. I had this last time i did the oil but made the mistake of doing yo the filter too tight before i tried it and ended up scrapping the filter getting it off!
Ian Jones - 16/4/13 at 05:03 PM
Hi can i just check that the F306 filter from halfords is good for a 893cc fireblade engine please, as the person at halfords could not say for sure?
(and halfords own make 10/40 semi synth oil)
thanks
ian
