Hi all, quick question, if i use a 2.0Ltr zetec flywheel and clutch can i use the release arm and release bearing from the mt75 or do i need a
modified release bearing? Any help will be much appreciated.
I've gone the zetec / type 9 route but I think Zetec did the MT75 one:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=04740003.jpg.small.jpg
You can use the release bearing and arm from the MT75 but it does depend on the clutch. I can't help as I got mine from Dunnel, who won't
tell you what it's from but you can bet it's a standard Ford item.
You could temp bolt it up and see if the arm moves without hitting the gearbox casting.
