I'm trying to sort out the electronics for my Pinto engine (F-reg). I've just stuck a posting in the Wanted section for the proper parts,
but I was wondering if anyone knew of reasonable substitutions that would work with the engine. I'm planning on changing the carb, so I
don't need to keep the same ECU as the original engine (with the stepping motor on the standard carb). The obvious questions are:
- will the dizzy/electronics from another Pinto work on this engine? There's a 1.8 Pinto in the breakers here that still has the relevant bits;
would that work? What about the advance curves.... are they compatible?
- Do I need a vacuum advance? There's a non-vacuum advance dizzy on Ebay finishing tonight, but I'm sure I read somewhere that it's
better to keep the v-a and that Weber recommends a v-a dizzy for all it's carbs.
- is there any comprehensive websites that can show me which bits are compatible? Maybe something with part numbers?
Sorry if I'm being a bit thick about this stuff, but I've only owned diesels for the last 20 years and ignition isn't somthing you have
to consider too often
John
Hi,
I have recently aquired an old-ish 2.o carb'd pinto, and my plan is to buy the Megasquirt kit with the optional ignition board, and then to make
my own throttle bodies. This (hopefully) will allow me to program any fuel and ignition map I like. The kit costs about £100 and the software is
free!
See http://www.bgsoflex.com/megasquirt.html for more info.
rather than making your own throttle bodies, it will be easier to get some motorbike ones from a breakers ( around £75 for a set of four from a honda blackbird, these are 42mm bore and have idle air bleeds top help with setting up.)
Hi John
The early 2.0 and all 1.6 pinto engined Sierra's use a very simple ignition
Dizzy with vac adv, ign mod only 5 wires and a matching coil
I've fitted the lot to my 2.0 pinto and it runs ok
Adrian
Ive also used a lucas setup from an early sierra that was easy to install and should provide all the sparks i need.Ive been told that i should use the non vacuum dizzy to run with my delortos but the manifold already has a vacuum take off so im going to give it a go,wish me luck.
Hi Adrian
Did you have to swap the dizzy as well as all the electronics, or did they just plug into the dizzy you had? So far I haven't seen many
distributors, but they all have had the same 3 lead connector on the side.
The one I used http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=ignition_module.jpg
was on an 85 2.0ltr and needed the distributor from the same car. The 1.6 used it as well,it's the inductive discharge system I think.
I use a standard pinto Ford dizzy with vacuum advance (with DHLAs) and it works fine.
Paul
Hi John
I had to change the dizzy as i'm using an injection pinto as a donor but using carbs
I got all the bits off the same car, including the wiring for £15
Adrian
New in the breakers this morning was a 2.0 G-reg transit with all the bits I was looking for. 15 minutes and £10 later, I was a very happy owner of a
complete pinto ignition system.
cheers
John
