Ive been quoted £200 to have new valve guides fitted, valve seats re cut and unleaded seats replaced in a Pinto head, is this reasonable.
Also been told that the ford unleaded seats that are already in the head are thin and have tendancy to fall out...anyone any knowledge or experience
of this happening.
I'd not heard of that particular problem, but that doesn't mean it doesn't happen.
£200 probably is fair for that much work and parts, but that is the point at which I would be wondering about changing the whole engine.
Hi there
I used Newark engines (GA classics) and i have to say the service and cost was fantastic. They skimmed the head, fitted new seats, guides, valves and
lapped them in. I think it was about £120. I had other work done as well including a block bored out and supply of pistons all on a 1300cc crossflow
not a Pinto. I would give them a try at least, ask for Dai, the foreman. He knows his stuff and very helpfull too. Good luck. Joe.
If you are not putting in bigger valves, I would not bother with re cutting the seats just lap them in.
A decent injection head is around £150 and flows better than a standard one.
why dont you just take your £200 and spend it on a zetec?
If you are going to have valve guides and unleaded seats installed there is NO way you will get away without recutting the seats. The whole point of recutting the seats is to remove pitting AND to ensure they are concentric with the valve guides as non concentric seats will not seal.
Thanks for the views, i may have a look for an injection head but i'm quite happy with the pinto so wont be taking the Zetec route, i will give Newark a call- thanks for that info
