Anyone know what other dipsticks are suitable for a C20XE, i've tried looking in local breakers for C20XE but no joy,
thanks
I can measure the operative length of mine if you need dimensions...
Have you asked your local VX dealer?
Pretty sure new ones are under a tenner.
Hi,
If you could measure length it would be appreciated, i tried VX dealer just now, £17.81 +vat, in local breakers there's a few 1.8 astra and a few
ecotec's, not sure if the ecotec has same dipstick
cheers
Originally posted by SandyC
Hi,
If you could measure length it would be appreciated, i tried VX dealer just now, £17.81 +vat, in local breakers there's a few 1.8 astra and a few ecotec's, not sure if the ecotec has same dipstick
cheers
Ok, by the way - I have shortened my sump, but I didn't alter the dipstick in any way.
from top of tube to tip is 346m
----------"------------HIGH is 323.5mm
----------"-------------LOW is 338.5mm
stopper diam - 12 mm.
width of stick - 4mm
thickness...... - 1mm
HTH, Steve.
By the way, whats a C200XE - is it a 20 - litre, 160 valve fire - breathing monster??
Many thanks Steve,
I'm hoping it's going to be a fire breathing monster, it was just a finger stutttter
thanks
