pinto firing order
fuz - 3/9/02 at 11:30 AM
i,m putting my engine back together and need to set up the timing.It says the firing order is 1 3 4 2, but from which end of the engine? do you count this looking from the gearbox end to the fan end or the opposite way round.
cheers
fuz
Alan B - 3/9/02 at 12:09 PM
From fan to gearbox, (Front to Back)
fuz - 3/9/02 at 05:20 PM
cheers Alan, thought it was, but I just thought i,d check. Didn,t want the engine to go bang incase i got it wrong!!!
fuz
Mike McKinstry - 4/9/02 at 05:19 PM
Have tried 2-4-3-1-doesnt go bang ,more like pop and spits out some flames-especially once youve poured some petrol down carb in desperate attempt to get the thing going!!!!
johnston - 4/9/02 at 08:40 PM
checku havent got the distributor 180 degrees out i.e firin on 4 when should be on 1
johnston - 4/9/02 at 08:42 PM
dis requard last post
i should read things a bit more carefully dohhhh!!!!!!!!
