Has anyone had any issues with the starter motor hitting the sump?
My sump (1.8 mondeo) has a bossing or bulge on the side which is preventing me from fitting the starter motor
Get hacking Just dont hit it with a hammer guess how I know.
I cut that section out and ad a plate welded inside the sump, initiallty tried grinding it dow but still not enough clearance
This is how I solved it
there are a few different starters some have a small body some large body. i used one from a 2.0 dohc sierra small body and a small amount of grinding
to the sump(i have an escort sump don't know if they are the same)
starter on passenger side of car hope this helps
[Edited on 29/4/11 by JAMSTER]
As said you need to grind the sump to give clearance for starter.
http://ec2.images-amazon.com/images/P/B0001GS0G4.01._AA280_SCLZZZZZZZ_.jpg
=partial success.
Just need to try and get a motor to fit now!
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=154501&page=1#pid1306133
lrs707 1.8cvh sierra 2.0dohc sierra
is your starter on passenger side or drivers side as there are different mt75 boxes
Passenger side
